Improper Hartford Loop
Ken_8
Member Posts: 1,640
The hartford loop enters the equalizer 2" above the NOWL (or LWCO set point level) instead of below?
I just encountered that one on a steam system that sounds like the anvil chorus on first steaming after a cold start (day/night morning start).
Many other things are wrong with the system piping, but I wonder what that particular error may be causing. I cannot see that item as a contributor to the cold start water hammer.
Comments please.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=68&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Comments please.
Ain't that what they call the Gifford Loop ?
I remember reading about that somewhere - either online here or in a magazine . Anyone know where to find info on it ?0 -
It seems the recommended Hartford loop height
varies with the seasons of the moon. There seems to be no consistant pattern in manufacturer literature other than at least above the minimum water line of the boiler. JMHO.
Boilerpro0 -
Really?
I thought all mnufacturers wanted it around 2" below the water line.
Oh well.
Yep , the ones we use
call for the loop to be at least 2 inches below normal water line . Hey Ken , I just found a 3 page article that goes into detail about the Gifford Loop . I had it stuffed away with some junk . I'll see if I can scan it and post it here . I hope that don't infringe on copyright laws .0 -
Looking foward to seeing the frank Gifford loop
I believe WM and Burnham have always said 2" below water line...as long as I've been doin it. MD
Here they are
It came out pretty grainy - I had to scan my copy which was not in good shape to begin . I had to save them as Microsoft Word Documents . If anyone knows how to change a Word Document to .jpg , feel free to change these .0 -
Ron,
Thanks!
Two people gave me a source for that and I found the archival resource - but not being a "member" of that particular authors "club"...
Two arms and one leg were the charges.
BTW, I suspect the reason the Gifford Loop never found much favor is becxause the possibility of small content boilers (like those of today) would have more water hammer if the return was that close to the steaming surface and chest dynaimcs. It's already "busy" enough in there without introducing cool water an inch or two below the water line - rather than the more common Hartford setup of say 6 to 10 inches below the NOWL?
But than you for digging that one out.
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
