Baxi Boiler
Billy_4
Billy_4 Member Posts: 18
Does anyone have experience with the Baxi boiler. It is a self-contained wall hung gas boiler with a plate heat exchanger for domestic. Just wondering if anyone has any feedback.
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,651
    Baxi
    is huge in Europe. Great stuff, very well-respected company.
    Retired and loving it.
  • Bob Anderson_2
    Bob Anderson_2 Member Posts: 4
    BAXI
    Yea - I bought one and it works great. Make sure that if you use the combi - check out the hardness of the water and make sure that 3.5 gpm (or so) will work for you.
    I bought it from www.houseneeds.com - they are vey good people. Talk to Gary about the Baxi.
    Let me know if you need any other info.
    Bob
  • Jimmy Gillies
    Jimmy Gillies Member Posts: 250
    Baxi UK
    Baxi I think ? is still a UK company.
    Yes a lot of boilers installed here in the UK are of this design. They are called Combi boilers - they are best fitted in small homes or flats. The only problem with this type of boiler is the hot water production - to produce a temp rise of 35*C (95*F) for hot water these boilers have a very large output 28/30KW (93 - 100,000 BTU). But if you install a boiler & an indirect hot water tank, the boiler can have half that size.
    I hope this is of some help.
    Regards.
    Jimmy Gillies
  • Kal Row
    Kal Row Member Posts: 1,520
    hint
    the avg shower is 2.5gpm - so for a real house, you
    need an indirect hot water holding tank with a pump
  • Baxi-Luna
    We've installed about half a dozen of them and have had no callbacks; nice units that can handle a medium hydronic load (~100,000 BTU input).
    Their combi boiler will provide you minimal (3.5 gpm) DHW which limits you to using one fixture at a time. So you can take a shower and use the sink, but not at the same time.
  • Jimmy Gillies
    UK Showers
    Kal.
    For the watering cans we fit here in the UK the stated flow rate is only 0.1 Ltr/Sec I think that's about 6 Ltr/Min (1.3gpm UK).
    Ever had a shower in the UK?? you got to dance around a bit to get wet !
    Regards
    Jimmy Gillies
  • Kal Row
    take a shower in
    "the land of warm bear and cold w..." (shhh, there might be ladies listening) - naah - I’ll just keep my Yankee what'cha'mc'all'it home
    the shower flow, is actually supposed to be something like that over here too, but all my customers take the restrictors out, they are all wrench turners and give me endless grief - i am getting a digital camera so that i can take pictures of how i leave a job - it's getting out of hand
