air in the pipes and banging pipes baseboard
mike92
mike92 Member Posts: 3
i took my single loop baseboard and zoned it into two zones.since i have done that i can't seem to get the air out of the system no matter how many times i bleed it.also the pipes make noise now when the heat kicks on in both rooms.also the one loop the last room on it doesn't seem to get hot.i know there is alot of questions but my wife just had a baby and i can't afford to have someone come in to fix it.any help would be appreciated
  • lchmb
    lchmb Member Posts: 2,997
    the noise is from the air in the system..you need to find where your getting the air from and take care of that first..check for leak's...if nothing else..a better explanation could help..is it circulator's/zone valve's/monoflo...where are your purge tee's..are you pressure feeding when your bleeding..are you bleeding the zone's hot or cold only?
