Indirect Hot Water Heater ( Phase 111 )
DDT.
Member Posts: 1
Can you hook a indirect hot water heater ( Phase 111 ) up to steam? If so please send us the instruction.
Thank you,
DDT.
Thank you,
DDT.
sure
send some cash and the instructions are yours!0 -
Which brand boiler
are you connecting to ? Many new steam boilers come with tappings to do that very thing . And the intallation manuals usually give good schematics to pipe them in . Peerless , Burnham , Weil Mclain to name a few - all have manuals online .
If its an older boiler you probably can do it also , just make sure you can hook into tappings on both sides of the boiler - one tapping up high , one lower , but both lower than the boiler water level .0 -
look
to the left DDT at heating Q&A. Dan has a section on condensate heating. Best Wishes J.Lockard0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
