Simple question
Scott Brink_2
Member Posts: 21
I know this may be a simple question, but here it goes.
How can I tell if the hissing from the radiator vents is air or steam? From what I understand, you shouldn't be able to see the steam. I was wondering because I think I have a couple of faulty vents.
Similar problem
I have a similar problem. I don't think its the vents that are at fault. I think what might be happening in my case is that my burner is overfired thereby trying to deliver more steam to the radiators than they can actually radiate. If you take the vents off (when the system is cool) and blow in them and air comes out then they are probably working ok.0 -
Steam is visable, air isn't
The vents should vent with a very low nonvisable hiss. When you see a foggy mist that is steam. If you have steam coming from the vent, replace it because it is bad.
JR
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0 -
Very Dry (optimal ) steam is nearly invisible
But you knowyou've got a bad vent when the rad is hot all the way across and at the vent, and its still!!!!! hissing and tell tale - spitting. Mad dog
true, but...
You can see the hot condensed fog formed from the steam, which most people will call "steam". Technically, dry steam is not visible, "wet steam" is actually both steam (gas) and water droplets/fog (liquid) mixed; you see the liquid part.
Once the rad is hot the vent should close and not make any hissing sounds. Leaking steam will rapidly fog a mirror or a glass sheet or a spoon, etc., held over the vent.0 -
From Mr. Wizard as a kid
Dry steam (the "invisible" kind) will ignite a wooden match. Wet steam (the visible kind that is really not steam but air and hot water) won't.0 -
If all the vents are closed
and the rads hot all the way across then the pressuretrol should sense that and shut the furnace down, correct? This lets air back in so that the cycle could start all over again. But if the pressuretrol does not shut the furnace down then will the steam eventually force its way out through whatever cracks/holes it can find?0 -
That was what I was thinking. I replaced a couple of the vents and now there is no more noise and I can hear a "click" when the vent shuts. What a difference when you can compare a brand new vent to an old one. The difference is clearly obvious to me now.0 -
The steam condenses
As the steam cools it condenses and turns back to water. The water or condensate returns to the boiler to get reheated and turned back to steam. A undersized boiler will run and run and never shut off. A properly sized boiler will run a long time before it has to shut off on pressure. In the spring and fall it could shut off on temperature before it shuts off on pressure.
John Ruhnke
If pressuretrol is broke..................
I think your questions was about what happens if the pressuretrol is broken and the boiler keeps making steam. The steam compress's. Pressure in the system keeps building up, and finally at 15psi the relief valve blows. If the relief valve is stuck, then the pressure keeps building UNTIL SOMETHING BLOWS UP. In the 1800's before relief valves, steam boilers killed a lot of people.
JR
- 86.5K THE MAIN WALL
- 53 Biomass
- 95 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
