munchkin gas leak
peter dawson
Member Posts: 2
We have installed a new controller 925, along with this we replaced he blower motor. There is a cork gasket between the blower and the gas valve. The new controller uses variable speed for the blower. We suspect at low speeds because of the lack of vacum the gas is leaking around the joint. The original blower always ran at full speed (old controller didn't support variable speed)
Try checking the gasket right under your nose!0 -
Did it ever cross your mind to call tech support?????????
800-323-9651 ext. 9250 -
Is there a tech support # that you can call on Sunday late that I don't know about?0 -
gas leak
I just came from one we installed awhile ago. Cust. claims he could smell gas intermittently. Two guys were there before me. I checked everything twice. Then I noticed that the pressure switch hose was off...no more gas leak...0 -
Sorry no Sunday night tech support
Unless one of us happens to be on the wall on sunday. Dose any other water heating equipment co offer these hours? 8am to 8pm mon thru fri and sats 8am to 11am.0
- 125 Chimneys & Flues
- 169 Indoor-Air Quality
