Hydronic floor boxes
Bill_18
Member Posts: 13
Does Slant Fin or anyone else still offer those " boxes with the element " that you would drop into the floor? I have a request for one but can't find them on Slant Fin site. Last I used them was many years ago in my helper days. I understand how H2O baseboard works with the convection current, whats the theory behind those boxes? Thanks.
Slantfin only sells
kick space blowers.
Beacon/Morris has natural convection floor boxes
http://www.beacon-morris.com
and others also make fan convectors for the floor:
http://www.mysoninc.com0 -
Floor Convectors
I haven't seen them available thru suppliers lately. If you don't provide for cool air to enter the box the warm air just sits there and doesn't really convect. I've retrofitted a couple that didn't work with baffle and it did the job. Here's a sketch I made for a guy.0 -
how about...
http://www.vrvproducts.com/html/body_qo_fl100.html
http://www.vrvproducts.com/pdf/install-fl100.pdf
Floor forced convection units -- sized to fit between 16" OC joists.0 -
Thanks guys. Thats the product I'm looking for.0 -
We just installed three or four on one job...
and the HO decided she wanted to paint the interior of the boxes flat black so you couldn't see into the box...
Also, if theres going to be hardwood flooring installed around the box, cut out a plywood lid and screw it firmly to the sub floor to keep the flooring guys from cutting their materials too close to the box to the point that the grate won't easily fit on finish.
Been there, didn't do that, wished to heck we had...
ME0 -
Thanks Mark
That first link didn't work to B/M. Theirs is probably the one with baffle I saw and got the idea for my retrofit baffle after someone installed a cheapie that just got hot INSIDE the box.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
