Argo transformers??
KBP&H
Member Posts: 48
Has anyone had problems w/ Argo zone control transformers,, recently installed two about 2 months apart, 2 different installations, 20 miles apart, and both failed--- NO Heat on a Sat night-- Try to keep the customers happy
I had 1 problem once...
w/ a zone valve control burning out the trany...might have been a fluke...it was easy to replace the 40va transformer though.kpc
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0 -
no
not ever0 -
X-former
Every time I have had a corrrectly sized x-former fail (burn up) has been because something else in the circuit has failed. Check your wiring and your wire (ohm it out have seen T-stat wire too ofen fail between the conductors) I only run 18 gauge wire or better Check your controls Spider webs can get wet and track to ground. Put a fuse in the circuit. Best wishes J.Lockard0 -
argo
Yes we've had trouble in the past, but they have been excellent with tech support and replacements. Don't use them anymore as they have pretty much lost their market share here and everyone sells the "green ones" now, not because of problems. It's a good product and have put in tons of them,. No more problems than anyone else's stuff.0
- 125 Chimneys & Flues
