Munchkin T80
Jared M
Member Posts: 31
If the T80 requires an LP conversion kit? I was told it doesn't but the boiler I received is clearly labeled 'Natural Gas Only'.
-Jared
-Jared
The T-80
can be converted to use for propane. When leaving the factory, it is set for natural gas. There is no conversion kit needed. If you call us at Tech Support on Monday morning we can talk you through it. As with any conversion, you will have to set it up for a proper gas to air ratio, using your combustion anaylizer.
Hope this helps
Chuck Shaw,
Technical Support Dept.
Heat Transfer Products
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0 -
Simple turning of the throttle screw call Chuck for details
Thanks guys...
I'll be calling on Monday!
-JaredM0
- 125 Chimneys & Flues
- 169 Indoor-Air Quality
