How often should I open the valves
Drod
Drod Member Posts: 59
that drain my condensate return line and my bottom boiler clean out? Mine is a single pipe steam system that's very clean and pretty efficient. I open the blow down valve once every week or two, but I'm not sure about the other valves.
  • Doug Wagoner
    Doug Wagoner Member Posts: 78
    What comes out
    when you open them? If your opening the valves blows out sediment continue. If it doesn't reduce your frequency. No need to waste condensate if it is clean.
