Copper Finned or Cast Iron
Mike Z.
Member Posts: 23
What is the difference???
one weights more?
but seriously, the CI, being more massive (also more expensive), heats up slower and cools down slower, giving more even heat. You also won't get then ticking noises from expansion w/ CI.0 -
Done both
Copper fin tube is more picky about flow and temps, however it is supposed to be much more resistnat to rapid changes in temp, as you get in baseboard systems and zoned systems. Cast iron is heavier and has more mass, but with many cast iron residential boilers only holding a gallon or two of water, the two are not as different as one thinks. Cast iron only holds about 1/10 the amount of heat as the equivalent weight of water.
Also, copper tube boilers do not deal with lower temperature water well, in my experience, despite what the manufacturers say. You need 140 F returns for copper, and cast iron can go down to about 120F on many atmospheric gas boilers.
Boilerpro0
- 125 Chimneys & Flues
- 19 Recall Announcements
