under counter heater
J.C.A._3
Member Posts: 2,980
Some "toe space heaters" have replacable motors. With some it's just less expensive to replace the unit. If it is just a surface mounted control that is not working, same thing. Some are easier to replace than repair.
Get a professional to look at it and make the call. Either way they will tell you the right answer.(we are all too busy right now to try and give you something you don't need!)Chris.
The heating unit in my kitchen is an under the counter type that is hooked up to our baseboard heating system. The unit has ceased working (the fan died)and I can't find a replacement unit. Any suggestions?
Thanks,
Daryl0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
