SYSTEM 2000
tate
tate Member Posts: 21
you can get a Baldwin filter #254 or equivalent. But, as others have said, you have a fuel quality issue.
  • Gary_7
    Gary_7 Member Posts: 25
    SYSTEM 2000
    Does anyone know of a compatible oil filter for an Energy Kinetics System2000 smartfilter? Any online sellers? Recently Ive been having to replace the filter about every 3 months and the smart filter is quite expensive, $25 a pop.
    Gary
  • Scott M_2
    Scott M_2 Member Posts: 26
    I believe a Garber filter will fit that.
  • Gary_7
    Would my local plumbing supply have the Garber oil filter? Do you know of anyone selling it online?
    Gary
  • Alan Muller
    Alan Muller Member Posts: 31
    EK filter cartridges.
    There are Wix and NAPA filters (they are Diesel engine fuel filters)that will also fit.
    But if you are needing a filter than often something is wrong in your tank or the way the suction is set up. You might want to get it pumped. And put a "normal" fuel filter in front of the cartridge filter (element costs $2.00).
    am
  • Paul Mitchell
    Paul Mitchell Member Posts: 266
    Sid Harveys
    sels them and will ship anywhere. They make their version of a Garber...the same and less expensive.
    To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"
  • Steve Eayrs
    Steve Eayrs Member Posts: 421
    You have a oil problem not a filter problem.
