STEAM TRAP/MAIN VENT LOCATING
Steamhead
Member Posts: 17,492
Measure the length and diameter of that main, and we'll tell you what you need. If you have any other mains in that system, measure them too.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=157&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"</A>
Consulting
Consulting
I'M NEW TO HOME OWNERSHIP (2 FAMILY) (STEAM--SINGLE PIPE)
AND I'M TRYING TO BALANCE THE SYSTEM AND PROVIDE MORE HEAT TO THE TENANTS(2nd FLOOR). I'M IN PROCESS OF CHANGING
THE STEAM VENTS ON ALL RADIATORS. I READ ABOUT THE "MAIN
LINE VENT"........THE ONLY ONE I LOCATE IS ON A UNION WHERE
THE MAIN AND THE RETURN MEET. WHEN THE BOILER IS IN OPERATION,STEAM IS FLOWING FROM THIS "VENT"(TWO SIDED,LIKE A TRAIN WHISTLE).IS THIS NORMAL? THERE ARE ALSO RUST DEPOSITS IN AREA OF VALVE.....SHOULD THIS BE REPLACED?
THANKS TO ALL!0 -
Not normal
You could try cleaning it by boiling in vinegar but sounds to me like it should be changed.0
- 86.5K THE MAIN WALL
- 53 Biomass
- 95 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
