BOILER TEMP
CHUCK HAWLEY
Member Posts: 2
I INSTALLED NEW HOT WATER BASEBOARD HEATING SYSTEM
WHAT SHOULD THE TEMP OF HEATING WATER BE LEAVING BOILER
I LIVE IN NORTHERN MARYLAND
I'm in Southern Illinois, but I set the limit on 180 degrees for baseboards0 -
temp
The industry standard is 180, however in your milder climate using an outdoor reset to use the boiler temp that is exzisting on the milder days may increase your fuel savings0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
