Shared Chimneys.
Rick_14
Member Posts: 1
Can I vent a gas boiler into a chimney shared with a oil burning boiler?
Generally \"NO\"
This is a question best asked of your aera inspector or fire department! Usually the two fuels should NOT use the same chimney.0 -
A rule of thumb is keep the gas flue at least 9" above the oil flue if you have to share the same chimney.0
- 125 Chimneys & Flues
- 169 Indoor-Air Quality
