Waterhammer in Autofeeder
Frank Weigert
Member Posts: 23
My waterpipes in the basement are shaking whenever the autofeeder starts to add water to my steamboiler. This only occurs when the valve just opens a bit. When I blow off the boiler fast so that the valve opens all the way, it does not occur. When I open the manual bypass there is no waterhammer. Should I look for the cause in the valve or should I just install a Waterhammer arrestor in front of the feeder ? In the beginning it was a nice feature since no matter where I am in the house, I always know that my feeder is working. After a while it get's a little bit annoying though. I am sure that there is some kind of long term effect on the pipes also.
- 86.5K THE MAIN WALL
- 53 Biomass
- 95 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
