Strange circulator noise
Ken C.
Member Posts: 267
I replaced a leaking bearing assembly on a Taco # 110 circulator today. The assembly was a factory rebuilt unit. I put six drops of lubricating oil in the oil cup prior to restarting the circulator. After a couple minutes, the circulator started making a continuous, high-pitched whistling noise. I put a bit more oil in the oil cup, and the noise went away, but came back after a minute or two. The only thing that quieted the noise was spraying WD-40 on the shaft seal. After I left the job, I remembered that I might have stretched the spring coupling before tightening the allen screws. The new bearing shaft was slightly shorter, so I had to stretch the coupling a bit longer to compensate. I wonder if the coupler being under (slight) tension could have caused the seal/bearing noise. Is it wrong to put any tension on the coupler, or do you think this whistling noise happened for another reason?
- 86.5K THE MAIN WALL
- 53 Biomass
- 95 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
