Wallies, let's put our heads together (SE)
Steve Ebels
Member Posts: 904
On the thread regarding the Munchkin price, Dave DeFord was wishing for a checklist of questions he could use to screen contractors. He has been looking for someone to do some work for him and is having trouble knowing what questions to ask in order to find a person or company that he is comfortable with. I think this would be an excellent idea. Maybe we can come up with 15-20 questions regarding business, personnel and technical issues regarding hydronic and steam heating to help folks like Dave out. I myself would love it if people would compare me and my business on issues that are important instead of price alone. As Dave said, often price becomes the determining factor because the average person doesn't know what else to ask.
I'll start out with a few basics.
1. Are you going to be doing the work or will you be sending someone else?
2. How many systems like mine have you or your people installed? (or serviced as the case may be)
3. What brand of equipment do you prefer and why?
4. What is the dollar amount of repair parts inventory you stock for equipment like you are going install in my home?
5. What do you do in the event I need service and you don't have the part in stock?
6. Why should I hire you instead of someone else?
7. Do you use a combustion analyzer when you set up the burner on my equipment?
Let's keep on going ................
How to find a good steam heating contractor
This is from We Got STEAM Heat!
So, Ive been telling you to find a pro and to avoid the knuckleheads. How will you tell one from the other. Heres a checklist of things to do as you negotiate with a heating contractor. Believe me; the good guys will thank you for being this thorough. An educated consumer is their best customer, especially when it comes to steam. Here goes.
Walk the contractor through your home and discuss your comfort concerns. If its too hot in this room and too cold in that one, let him know. If there are gurgling or banging noises in the pipes or radiators, mention this, and ask the contractor to suggest a remedy. Dont expect a new boiler to magically solve your system-related problems. Explain to the contractor that youre buying comfort, not just a new boiler, and that you expect the entire system - boiler, pipes and radiators - to work properly when the job is done. At this point, a good heating contractor will most likely explain your options. Dont be surprised if those options add to the cost of the job. Many steam systems, as you now well know, suffer from ailments that have nothing to do with the boiler. When the contractor suggests these changes, ask if he will guarantee the results. A good heating contractor will. If hes not willing to stand behind his work, theres a good chance hes a knucklehead. Call someone else.
Dont let the contractor base the size of your new boiler on the size of your old boiler. He must measure your radiators and analyze their ability to condense steam. If he bases the size of your new boiler solely on the size of your present boiler, hes discounting the possibility that something may have changed during the past 70 or 80 (or more!) years. Hes also acknowledging that the original installer was infallible (and we dont even know who that guy was). If the contractor says, Well, the old one worked well for years so lets use the same size, know that this guy is not someone who pays attention to details. Show him to the door.
Also, dont let the contractor base the size of your new boiler on a heat-loss calculation of your home. Heat loss calculations mean absolutely nothing when it comes time to replace an old steam boiler. These calculations mean a lot when youre sizing the steam radiators, but youre not replacing the radiators, are you? Remember that steam is a gas that will eagerly condense on cold metal. The boiler must be able to make enough steam to reach the furthest radiator before all the steam turns to water. In other words, the boilers ability to produce steam must match the systems ability to condense steam. Theres no way around this. If the new boiler is too small, parts of your home will probably always be cold and youll burn more fuel than you should. If the boiler is too large, the burner will short-cycle, run inefficiently and the burner parts and controls will wear out long before their time. And again, youll burn more fuel than you should. If the contractor doesnt take the time to survey and carefully measure your pipes and radiators, he doesnt understand steam heating. Tell the knucklehead to have a nice day and then show him the door.
The piping around a modern steam boiler is crucial to the production of dry steam (steam that contains no more than two percent water). If the steam is wet, it will condense before it reaches all of your radiators. Youll wind up with high fuel bills and uncomfortable rooms. Nowadays, most reputable steam boiler manufacturers consider the piping immediately around the boiler to be a part of the boiler. They publish installation booklets showing the contractors how they must install these boilers. If a contractor doesnt follow the manufacturers instructions, the boiler wont operate efficiently, and theres a good chance the manufacturer wont honor their warranty should you have a problem. So, insist on seeing the installation-and-operating manual beforehand. Have the contractor show you the correct near-boiler piping for the unit. Have him explain it all. And have him include in his contract a clause saying that he will install the boiler according to those instructions. This alone will scare away heating contractors who dont know what theyre doing when it comes to old steam systems. A knowledgeable contractor will never object to this very reasonable request.
Dont accept copper tubing for the boilers supply piping. Copper expands and contracts much more than steel. Because steam piping can twist into some odd angles, the expansion of the copper often puts a lot of torque on the soldered joints. That twisting frequently causes the joints to come undone after a few years. And then youre on your own. Copper can also leach out into the boiler, shortening the boilers life through dielectric corrosion. Proper steam piping calls for threaded steel pipe and fittings. The threads allow the steel pipe to twist without coming apart. Copper tubing is what the low bidder will offer. If youre planning to stay in your home for more than a year, insist on properly installed, threaded steel pipe.
Modern steam boilers sometimes dont get along well with old chimneys. Make sure you ask every heating contractor who steps into your home about your chimney. This is for your safety and protection. An old chimney may need to be lined with stainless steel to keep the flue gases from condensing on their journey to the top. Condensing gases form an acid that can eat through the mortar and cause parts of your chimney to fall apart. This, of course, can lead to poor venting of the products of combustion, and potentially dangerous levels of carbon monoxide in your home. Carbon monoxide is deadly. If the contractor wont talk about your chimney - if all he cares about is the boiler sale - he is not a professional. Go no further with this person. And know that a stainless steel chimney liner isnt cheap. Youll risk your life if its needed and you try to do without it, though.
Steam pipes must be insulated to keep the steam from condensing before it reaches the radiators. In the old days, we used asbestos. Nowadays, we spend a lot of money removing the asbestos, and we rarely replace it. Most folks figure the heat isnt lost because its still inside the house. But if the steam is condensing in your basement pipes, it wont be condensing in your bedroom radiators on the second floor. Youll be burning lots of fuel and youll be miserably cold in some of those rooms. You know all of this by now. If your steam supply pipes are uninsulated, have the contractor include a price for new insulation. Or insulate them yourself if youd prefer.
Reputable boiler manufacturers also include thorough cleaning instructions in their installation-and-operating manuals. The contractor must follow these instructions if your new boiler is to make dry steam. Have the contractor show you these instructions, and have him write on the contract that he will follow them to the letter. Then make sure he does. It takes nearly a full day to properly clean an old steam system. There is no chemical or magic potion I know of that can make decades worth of dirt vanish. Dont accept shortcuts. And so that youre better able to compare prices, ask each contractor to give you the price of the cleaning as an addendum to the installation contract. If he tells you the boiler doesnt need cleaning, and that he can solve any problems with a few cans of chemicals after the job is done, hes a knucklehead.
Have the contractor install a drain valve in the boilers mud leg. The mud leg is the drum at the very bottom of the boiler, the place where sediment will gather. If you dont insist on this drain valve, you probably wont get it. Most contractors will leave the drain valve out to save a few bucks, but without it, you wont have a way to flush sediment from your boiler as the years go by. Dirty boilers have shorter life spans than clean boilers. How often do you want to buy this thing?
If youre not going to do it yourself, get the contractor to inspect your air vents and replace them if necessary. Youll find these air vents on your radiators (if you have a one-pipe steam system) and near the ends of your mains (on both one- and two-pipe steam system). Good air vents make a dramatic difference in system performance. Even a brand-new boiler will gobble fuel if the air vents are old and clogged. Be prepared to pay extra for the vents, and know that theres a definite range of quality when it comes to these things. Like all things in life, you get what you pay for. Buy well from a reputable supplier, and take comfort in knowing that this is one of the best investments you can make in your old steam system.
Heating contractors buy their equipment from plumbing and heating wholesalers who handle specific brands of boilers. Since the wholesaler extends credit to the contractor, the contractor will usually buy what the wholesaler stocks. Because of this, you may find it difficult to get three or four competitive prices if you base the comparison on a particular manufacturers boiler. Thats because the quoting contractors buy from different wholesalers. If you ask for Brand A and the contractors wholesaler stocks Brands B or C or D, he will try to sway you to the brand that hes used to installing. Theres nothing wrong with this. Rather than try to level the playing field by having them all quote on a certain brand of boiler, or a certain model number, do this: Let each contractor quote on what he thinks will best heat your home, but have each contractor guarantee the results in writing. Have them say, for instance, that when theyre finished, your house will heat evenly, and with no noise or squirting air vents. Some contractors will run for the hills when they realize youre buying results instead of just a boiler, but youre better off without those guys anyway. A good contractor will talk to you seriously about your systems problems and their solution. Hell most likely suggest things that go beyond a simple boiler replacement. There are people out there who have no problem guaranteeing results.
And know that competent steam contractors generally charge more for a boiler replacement than others, but these guys deliver those wonderful results - increased comfort and fuel savings. They will never be the low-bidder, but they will do what they say theyll do, and I think theyre well worth their price.
A very good place to meet many competent contractors is on the Wall at our website, www.heatinghelp.com.
You can also ask questions at your local plumbing & heating supply house. Stop by at a time when theyre not that busy (not first thing in the morning or late in the day) and ask if you can speak to the Heating Guy (most places have one). He wont be selling you anything because his customer is the contractor, but hell be able to tell you about the good guys in the area.
Finally, know that a good steam contractor doesnt have to be old. Some of the sharpest steam contractors I know arent even 40 years old. Each of them has done the research, though, and each has a passion for this stuff. Thats the guy youre looking for.
Retired and loving it.0 -
Homeowners and steam heat
That's good but
How about a short list that a homeowner could use to help sort the wheat from the chaff?
The best thing any homeowner can do is to become knowledgable enough about their system to know when they are talking to someone who is the real deal.0 -
Which is exactly why
I wrote the book.Retired and loving it.0 -
This content has been removed.
More...
May I see your contractors license?
May I see a copy of your current liability insurance?
May I see a copy of your workmens compensation policy?
Can I have the names, telephone numbers and addresses of the last six customers that you did this same service for?
Do you have any disgruntled customers, and if so may I have their telehone number? (If they say no, they're fibbing..)
Call the city, BBB and any other consumer protection organizations that may have a track record on the contractor.
In general, DO YOUR HOMEWORK BEFORE you sign on the bottom line.
ME0 -
some questions for the contractors or potential contractors??
I would love to see customers ask a few things some possibles are: Is ALL your work supervised by competant J-men and ask to see thier certs, licensure etc.? What types of training is provided thru the contractor to keep their employees abreast of the industry? Ask what type of reputation they have with the mechanical inspection dept. and the Better Business Bureau?? THAN CHECK. . . . Ask for a number of two of ref's who have contractors system in place. Also don't be afraid to offer to be a reference for a reasonable discount??? I for one have no problem offering this option right up front it's worth it's weight in gold, nothing will sell a product like a happy customer. Thanks again for the great site Dan!!! It just keeps getting better n better Aqua-Man0 -
A little long
Dan, you lose interest when you go that long in a reply. I hope you can get that down to a few sentences in the future. Tim0 -
Thanks for the advice, Tim.
But I don't seem to be losing my audience's interest. We've sold thousands of copies of that book to homeowners in the past month. We've also sold a lot of ProPacks to contractors who want to use the new book to their advantage.
But I could be wrong. ;-)Retired and loving it.0 -
Emergency service
Do you have 24 hr service? What is the number? ....Wait till 10pm one night and call and see what happens...Answers alot of questions.
Paul
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
