Flue Hole
Tom_42
Member Posts: 63
I was examining my boiler to see what the system is and I noticed a small hole (like for a screw) in the metal flue that leads to my chiminey. Not sure if this is good or bad. Can someone advise?
Thanks!
Tom
Thanks!
Tom
Is it oil or gas?
If its oil often times there is a hole drilled in the side to test for combustion. You could put some foil tape on it or place a screw in it of the same size. kpc
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0 -
Oil it is
I just wanted to make sure that no harmful gas was entering my basement. Thanks!0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
