Multi Steam Boilers
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,610
http://www.heatinghelp.com/newsletter.cfm?Id=17
It pays to wander off the Wall.
Retired and loving it.
  • Richard D._2
    Richard D._2 Member Posts: 156
    Multi Steam Boilers
    What would be the best way to pipe 2 Steam boilers together.The total load is about 860'000 btu.The customer ask about multi boilers,So I want to find out if it worth it for the customer to install it ..They will be oil fired..How much larger should I make the header? There is a condensate pump as well!Sshould I make a hartford loop for both boilers??How much larger should I make the equalizer ?How should I stage them? What evver you can tell me would be a great help,
  • Richard D._2
    fpr the lead Dan...Richard
