Whats the head loss through a Watts 1107 tempering valve?
jackchips_2
Member Posts: 1,337
> Does one of the Wall's experts have information <BR>
> on the head loss through a Watts 1107 tempering <BR>
> valve at flows of 3 to 8 gallons per <BR>
> minute?<BR>
> <BR>
> I've found a graph on their web site <BR>
> that shows a pressure drop of 4 psi at 4 gallons <BR>
> per minute flow. My mathmatical intuition is that <BR>
> this equates to about 10 feet of head loss butI'm <BR>
> not certain of my method. (Water weighs <BR>
> ~.43lb./square inch per foot of depth so 4 psi = <BR>
> about 10 feet of head. I'm hoping that this is <BR>
> way off base as it would really reduce flow in <BR>
> the system involved.<BR>
> <BR>
> Thanks for you <BR>
> intelligent thoughtful feedback.<BR>
> <BR>
> Hugh <BR>
<BR>
> minute?<BR>
> <BR>
> <BR>
> Thanks for you <BR>
> <BR>
> Hugh <BR>
<BR>
head loss
Does one of the Wall's experts have information on the head loss through a Watts 1107 tempering valve at flows of 3 to 8 gallons per minute?
I've found a graph on their web site that shows a pressure drop of 4 psi at 4 gallons per minute flow. My mathmatical intuition is that this equates to about 10 feet of head loss butI'm not certain of my method. (Water weighs ~.43lb./square inch per foot of depth so 4 psi = about 10 feet of head. I'm hoping that this is way off base as it would really reduce flow in the system involved.
Thanks for you intelligent thoughtful feedback.
Hugh0 -
The static pressure loss
is 0.433 psi/ft. so 10 feet would be 4.33psi. You were correct.0 -
I guess those science courses years ago did stick some useful stuff in my brain. Now if I add in the piping losses it will be cake to estimate system flow.
Thanks for the quick reply,
Hugh0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
