the best insulation to use for 4 inch underground return
d. nyzankiwsky
Member Posts: 1
what is the best insulation to put around a 6 in steam pipe underground ( houses in stone tunnel) pipe is slightly coroded but will replace pipe in spring as too cold to do work now.(Below zero) Replaced pipe in return pipe (4in wide) due to large hole but this pipe will need to be replaced in spring.
Boiler is large boiler that heats 30 rm hotel/ Underground steam pipe has been there well over 50 years.
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
