Need to repair C.I. radiator
Emil
Emil Member Posts: 3
Is it possible to repair a hole in a cast iron steam radiator (end section)? The hole is about 2 square inches, and irregular shaped. The repair will have to include a thread for the vent.
  • Dave Stroman
    Dave Stroman Member Posts: 765
    I think you should cut your losses and get another radiator. I can help if you are in the Denver area. Otherwise, look around for another one.
