Domestic Coil Removal Question
Drew Mullen
Member Posts: 1
For a number of reasons I am no longer using the domestic coil in my Teledyne Laars Boiler. I have simply cut the pipes off about a foot away from the boiler. I am wondering what settings I should change the aquastat to, or if I should get a different aquastat now that I do not need hot water in the boiler all the time. Any suggestions would be appreciated. Also, should I worry about removing the coil, or will it just be fine where it is.
Hi, I have basically the same boiler the Trianco DBC-125 with a 1.10x70* nozzle. I to do not use the coil. I cut mine about 4 years ago. This spring I am going to tackle removing the coil, due to lime scale forming around the in and out connections. They make a replacement plate with just the hole for the aquastat well. As for the aquastat settings I still use the L8124A triple. I keep the high at 180*, the low at 160* and the diff at 25*. During the off season I don't shut it down, I turn the low to 120*. Anyway thats how I do it. If anyone has a better idea let us know?0 -
aquastat settings
Harry, without a coil, there is no real reason to leave the boiler at low setting of 160 with that high a differential. These settings are to keep the boiler hot for domestic hot water. With the high at 180 and you're heating OK, I assume you are in milder climate that here in Maine. I would set the low around 125-130 and turn the differential down to 10. Check with the manufacturer of your boiler for recommended low minimum temp and use it as a true demand start boiler. It will recover OK and will be more efficient, especially in milder weather.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0 -
Al
Come on Al,... 10 degree diff?0 -
why not keep
20° or 25°diff w/ the 130° Min? That way when it does fire on diff it will burn longer but fire less often.0 -
I thought it was Boiler makes domestic water=lower Diff like 10*. Boiler does not make domestic water=higher Diff like 25*. Sound about right?0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
