Waste OIL Boiler
S Davis
S Davis Member Posts: 491
Any one know of a good waste oil boiler?
Need one between 100,0000-200,000 BTU's.
I have used Reznor before but they stopped making their smaller sizes and the smallest they make now is 350,000 BTU's.
S Davis
  • Floyd_5
    Floyd_5 Member Posts: 418
    Use the search feature here....
    A quick check, shows that HR did a job with a "Clean Burn" unit last year...check with him.
  • Mark Wolff
    Mark Wolff Member Posts: 256
    Here you go
    All the auto shops here in Kodiak, AK use the Black Gold waste oil heaters. The EL140H model runs 140,000 btu/hr, the EL200H runs 200,000 btu/hr. Either of those should fit the bill.
    I am impressed with the unit and don't hesitate to recommend it. Your customer should be quite happy with it.
  • Ted_5
    Ted_5 Member Posts: 272
    Viessmann has a great
    boiler for this, Vitola or a Vitorond. The Vitola can have return temps of 60F with out worry and the Vitorond 110F. You have to get a burner from INOV8 International ask for
    Andy Daley 1-877-684-6688 www.inov8-intl.com where are you located, maybe I can help.
    Ted
  • S Davis
    Any one heard of Econoheat waste oil boilers from Omni ,a customer found this brand on the internet and would like
    to use one.
    S Davis
  • Mark Eatherton1
    Mark Eatherton1 Member Posts: 2,542
    Be careful what you call it...
    The EPA has some pretty explicit rules regarding the burning of waste oil. I think what you're looking for is a "used motor oil boiler", not a wate oil boiler...
    You DON'T want a visit from the EPA.
    ME
