check valve question
Jack_15
Member Posts: 12
check valve presure rating is 150wsp and 600wog.
What does wsp & wog stand for?
Thanks,
Jack
Thanks,
Jack
They stand for
working static pressure and water/oil/gas. The WOG rating must be interpreted from a chart based on the working temperature. A 600 WOG valve will only be good for a maximum pressure of 600 psig up to about 135 F. As the temperature increases, the pressure decreases.0 -
Thank You,nm
Actually...
... the WSP stands for (depending upon the source), "working steam pressure" or "wet (as opposed to superheated) steam pressure". Either way, a 150 WSP rating will correspond to a steam temperature of 366*F, and a 125 WSP to 353*F.
The WOG (water-oil-gas) rating is usually based on 100*F, and is always higher than the WSP rating.0 -
I stand corrected - another example
of how important it is to put your mind in gear before you release the clutch on your mouth (or your keyboard!)0 -
I've...
... paid particular attention to piping for a lot of years. At least once a week, I learn new something new about it.0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
