old burnham fans/vapor heaters
john_27
Member Posts: 195
I have two large 1920's Burnham heat fans supplying air to a large first floor indirect system(see "Lost Art")...inside was a device to automatically supply tap water to the unit...as the steam tray inside the unit heats up, water vapor is supplied to the ducts....goes throught the indirects and out into the first floor....two questions......any risk of Legionaire Disease if we have water in them as intended, and....each unit had a solenoid gate valve on the return ....why didn't they use a broomell p fitting...john
sorry...units are actually bryant dualators...250k each0
- 86.7K THE MAIN WALL
- 54 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 934 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
