Duplex steam condensate return pump
Mark_5
Member Posts: 2
We are bidding on replacing a leaking duplex pump & reciever tank... We can't seem to locate the original equiptment manufacturer wonder if anyone knows if they are still around ... F T Pump Inc. 139 Market St. Kennilworth , N.J. was their last known address... We're trying to replace the tank with one of a similar size to fit in the exhisting pit. It's approximately 70 gallons. Hoffman makes a cast iron unit ... which is what we prefer, but the pump configuration is different than the exhisting one. Another manufacturer has a steel tank which we're trying to avoid , although they say they make it in galvanized. We're not comfortable with the galvanized in the steam system. Do any of you have any expierence with this , & it's longevity? Mark
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
