oil tanks
Anthony D.
Member Posts: 63
Need to install (4) 330 Gallon indoor tanks in a commercial building. Not sure of the best way to install the tank Fill & Vent piping, and the supply and return to burner.
Can someone point me in the right direction?
Thank you.
Thank you.
Look in the oil code for your State.0 -
I like
To run separate fill pipes, and to tee the vents together, with vent alarms in each tank. All 2 inch black with swing joints.I never liked to crossover deal. Then tee the bottoms together and run a single line to the burner. Line size depends on a few different factors. The fuel pump spec sheet will tell you this.
Andy Morgan
R. Morgan Mechanical, LLC0 -
Re read the message
Look in the code books, I am not quite sure, but I don't think that amount of storage is allowed inside a building.
I read it as two tanks!
Andy Morgan
just a suggestion
Not to sound bad..but you do not sound to be someone who is familier with the code's related to oil in your state..although it may cost a little more in the long run, I highly suggest you contract to a proffesional in your area...not only will it get done legally..it will be his back busting to get them in...0 -
NFPA-31
NFPA-31 is where you want to look. I have 2001 edition at hand. I am looking at page 31-18,31-19.
660 gal max capacity. Section 7.5 . You can store more oil if you have 2-3hr fire rated walls and special construction0 -
Roth
Look into Roth they have a nice setup for mutiple tanks. What ever road you take look in local codes and hire a pro you can very easily have a real mess if it is not done properly.0 -
The way I read it Bill..
> 31-18,31-19.
..is you are not allowed to use a "single" tank of more than 660 gallon, but you can use multiple tanks upto a maximum storage of 1375 gallon. (See 7.5.13.1)
Ands if you read 7.5.13.2 if the tanks are separated by the 2 hour wall you can have upto 1375 gallon in each area.
Both these senarios are when tanks are not in a dedicated room.0 -
According to the NFPA31
It looks like I can install upto 1375 gal. maximum (according to NFPA31 page 31-19 / Section 7.5.13.1,)as long as no single tank exceeds 660 gal.
Since this is an indoor tank installation I chose to use 330 gal. tanks.
But the code book only shows a pipe hook-up for a two-tank set-up. There is an illustration for more tanks, but only for listed or engineered fuel storage system.
I don't want to run four seperate fill lines if I don't have to, maybe I could pipe two tanks as shown in figure 7.5.15, and do this twice. Then common the vent lines, using one vent alarm per two tank combo.
Sort of a hybrid between what I was thinking and your original advice.
any suggestions?0 -
what makes you...
...think I'm not familiar with codes or a professional in this industry?0 -
the wording
of your initial question on fill/vent/supply/return plumbing. It can be interpreted anywhere from lack of familiarily w/ any oil tank plumbing requirements to just a lack of familiarity w/ requirements for requirements for setting up more than a pair of tanks. It is also not clear if you are in a state with very strict & specific codes/requirements for oil tanks or one that only has some basic requirements. No question is a foolish question, better to ask and learn!
You also might try http://oiltechtalk.com/ the "discuss" page for more input for your locality.
Stay out of the hot sun! (especially if your in N.E.)!
I may not have been
clear on the question. My question was on the proper way to interconnect multiple tanks. I have worked with many oil systems over the past 20 years, but have never had to replace/install multiple tanks.0 -
You cannot put in more than 660 gallons
and connect it to a single burner unless you have an 'engineered' or 'listed' system, FACT!
NFPA31-2001
Be careful of 'sales claims', they don't hold up in court, BIG FACT!0 -
Thanks for the advice, but what about when you are supplying six boilers in various locations, with the use of tranfer pumps and auxillary tanks.
What if I connect them so two 330 tanks feed two or three boilers and the other two to feed the rest?0 -
According to 7.5.13.1
you can not install an "individual" tank exceeding 660 gal., but you can have a multiple tanks upto 1375gal..
I do see what your saying in 7.5.15.1, but I not supplying only one appliance.0 -
The drawings in the appendix sum it
up a lot beter than time and space will allow here.0 -
Thank you, I'll check it out.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
