Wirsbo Tru Flow?
Jamie_6
Member Posts: 710
Is it OK to mount it upside down?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=289&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"</A>
Truflow
Jamie:
No I have been told by numerous people at wirsbo that the Truflow manifolds cannot be mounted upside down. They need to be installed upright, or left or right.0 -
The concern.............
is the issue of getting accurate flow measurements when upside down. The static weight of the water is supposed to effect the readings. I'll let you know since I had to see for myself :-)
hb
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"There was an error rendering this rich post.
Low end resolution
You will loose some of the low end resolution on the flow meters when they are mounted upside down. It has to do with the apature and spring assembly loading on itself. Other than that it is not a problem. A new instruction sheet that reflects this data is available on our web site.
Tim D0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
