need a little help
Mad Dog
Member Posts: 2,595
another name for it???? Mad Dog
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=299&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"</A>
Why
Ductboard? David do they the customer like the way it grows mold or blows apart. Have taken so much of that stuff out nasty. We do it once with metal and duct wrap. J.Lockard0 -
Noise reduction
Modern studios require almost incomprehendable sound deadening. The ductboard is used most of the time to eliminate noise traveling through the ducts. Studios are very moisture sensitive so a dehumidifier is probably planned, hence no mold. Am I right David?0 -
Sound
New orchestra hall in my town. You can walk through the supply ducts. Noise engineer said the key to low noise is big ducts at low velocity but same needed volume. You may want to see how large you can go.0 -
David, I'm sorry it took so long to find this I had to dig through the old text books
Red tool = 2 3/4
Black tool also = 2 3/4
I can't remember what the blue tool does If you can remind me I'll try to look it up.
By the way if you'll e-mail a fax number to me I'll gladly send you a few pages from my Owens Corning Manual.
Your friend in the industry,
Alan R. Mercurio
Oil Tech Talk0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
