steam boiler
kid plumber_2
Member Posts: 6
i keep adding water to a steam boiler about 3/4 to a half gallon a day ,vents are leaking .would it use this much water .
depends
on how many vents are leaking, and how bad they leak..does sound excessive tho..have you flooded the boiler to check and see if it has a hole in it?0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
