Replacing old radiator vents
Jim S
Jim S Member Posts: 82
When faced with the possibility of replacing old ,original looking vents on steam radiators ,what tricks do you guys use?
I`m especially interested in what you do when they snap off and leave a stub of pipe in the radiator.
    Steamhead Member Posts: 17,503
    Those vents are brass
    so if they break off, just drill out the hole and run a 1/8-inch pipe thread tap thru it. Then install the new vent.
    To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"
    Consulting
  • Jim S
    Thanks for
    > _A
    > HREF="http://www.heatinghelp.com/getListed.cfm?id=
    > 157&Step=30"_To Learn More About This
    > "Find A Contractor"_/A_
  • Jim S
    Thanks steamhead
    I appreciate the tip.
  • David Efflandt
    David Efflandt Member Posts: 152
    Easy-out & pipe tap
    It may help to have a 1/8" easy-out handy (kind of like a course reverse threaded thing that can fit inside if a broken nipple), along with 1/8" pipe tap to clean gunk out of the threads so you don't strip them.
    I have one that is stripped and almost just held in by the pipe dope, but that is good enough at such low pressure. A couple of mine won't budge, but work, so I haven't touched them.
