gravity boiler
ed wallace
Member Posts: 1,613
need advice looked at a boiler today old bryant boiler with 2 pilot lites and a baso safty switch by the time i got there customer had gotten system running again i advised him its time to replace system he wants to stay with a gravity system boiler is rated for 300,000 btu input 260,000btu output 2 3in mains off the boiler who makes something like this? any ideas
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=256&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"</A>
i know weil-mclains
are popular gravity hot water replacements around these parts.0 -
weil mclains and
smith's are set up with 3" tappings off the top of their sections.0 -
crazy
Your customer will save money if you put on a circ and make it a reverse loop system instead of standard loop. Make the first supply the last return, etc.
Paul
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0 -
gravity boiler
customer really wants to stay with gravity flow because its quiet
Gravity
Set up the control system with solar and battery and he'll be the only building with heat in a blackout!0
- 86.6K THE MAIN WALL
- 54 Biomass
- 100 Chimneys & Flues
- 5.6K Gas Heating
- 101 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 934 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
- 48 Job Opportunities
