Burner linkages
Tim_15
Member Posts: 8
Can someone explain to me the geometry of burner linkages. I know the mod motor and the damper or gas valve are set up linear to each other on a 45 degree angle..But I read that if the driven part is up at 10 degree angle it opens slowly the first one inch of travel..That is the confusing part for me. And how does having the driven part being at 70 degrees make it open more quickly..Any help will be appreciated.
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 943 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
