2 Zones for Steam Heat
RH
Member Posts: 2
I have a 1940's cape with an expanded second floor. The heat works OK on floor 1 but usually shuts off before I can get the 2nd floor realy warm. Also, at night I only need to heat the 2nd floor where the bedrooms are and do not want to run the boiler at 75 degrees to drive heat upstairs. Can I put a second zone in for the second floor?
upstairs
Rather than zoning, you might try bigger vents on the bedroom radiators (I assume you have a one-pipe steam system). That may equalize the heating between floors, and for just the rooms you want to heat.0 -
and
if the steam pipes in the basement are not insulated, steam will condense there rather than go to those upstairs radiators. If the basement is really warm, that's your problem.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 929 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
