co tester
berd_2
Member Posts: 7
i am looking for a co tester for testing gas and oil furnaceses. also is there a book or a class that shows what to look for ? i am new to this industry.
Bacharach!!!!
I use the Fyrite Pro125, and it is an impressive tool. Continuous sampling, so you can quickly see the results of any burner settings you change.
Bacharach's web site also has a great training section that you can spend literally HOURS browsing.
Starch0 -
CO tester
You may want to attend class before you make your selection of instruments. Check out www.ncinstitute.com for the next class in your area.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
