Short cycling of boiler
Jeff Bidell
Member Posts: 1
Our Boiler cycles on and off 60 to 80 times per hour in mild weather. Will increasing the system volume have any affect on this? Is there a minimum water volume or rule of thumb for hydronic systems? It does not have modulating control or a multistage burner.
Need to determine why
Withbthat e-mail address you should be able to get a heat loss calc sheet
First determine the load of the building, then see how closely the boiler output is matched to it.
Multi zoned, micro loaded systems can present short cycling on mild days, especially so if the equipment is grossly oversized.
Get us some more info to come up with ideas.
hot rod
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0 -
Driving tacks with sledge hammers...
I promised my partner I'd come up with a new saying. We've kinda worn this one out:-)
Even with modulation, if the system is grossly oversized you can expect short psycling. Size to the "real" load, as proven with historic fuel consumption. Then go with modulation of flow as well as heat.
How about "Driving a Volkswagen with a 427 cubic inch engine..." Two position. ON or off.
Any other suggestions for sayings to describe this??
ME0 -
Heh. That's called binary driving.0 -
If its single zone or just a few
I'd check the themostat anticipator settings. See this problem all the time
Boilerpro0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 929 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
