EMERGENCY!!!
bryan_10
Member Posts: 7
That's right, someone turned t-stat to a/c in unoccupied Catholic Church Rectory. We froze every rad and 12 of the 16 are cracked. What should I do? The rads are recessed A/S convectors(circa 1952). Is there end sections available to replace what I have? Do we get rid of the cast iron rads and go to copper fin-tube? Just replaced the boiler this fall, luckily this is not a boiler problem, but it is MY problem. Any ideas would be appreciated. Bryan
Use the "find a professional" tool to get someone local. You'll need some help right away, I'm sure.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
Cracked
The "Sunrad" type A/S rads are still made. Just not by A/S. My local wholesaler stocks many sizes that are virtually identical to the 1950's rads you describe. I cannot believe that item is very hard to get.
But if I'm wrong, try my wholesaler; Birdsall @ (908) 862-4455.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0 -
temp heat
For temp heat you can place a hydro-coil in the air handler or set one or more in place. We saved several old air handlers for this purpose & use them on job sites.
where
are you located? Could really use some replacements. Bryan0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 929 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
