Radiant, Hot-water heaters, & Pennsylvania
Jamie_6
Jamie_6 Member Posts: 710
I have a small radiant job that requires 7,000 Btu's of 140 degree water for a Wirsbo Quick Trac job. I would like to use a 40 gallon hot-water heater with a flat plate heat ex-changer for the radiant side and a mixing valve for domestic use. I would like to know
1.Is this possible?
2. Has anyone done it?
3. Is it ASME compliant to do it this way?
Thanks agian,
Jamie
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=289&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"</A>
