boiler pump
DaveGateway
Member Posts: 568
On primary & secondary pumping , when exactly is the boiler pump running? when the boiler fires? always on? or when a zone is calling? I have always done boilers the "regular way" but I now like to put the circ on the push & feed at the point of no pressure change {dont know if I said that right?} That's about as fancy as I've gotten [ha ha] & still alot of my peers don't know what I'm doing! I've done plumbing 18 yrs & I learn something about heating here every night! Thanks guys! love the photo's keep em'coming
boiler pump
It depends on the control system you are using. If you use a reset control, the pump will run only when the loop needs some heat. If you're using no reset, the boiler pump would normally run with the boiler....there are many options here
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
