Converted Gravity System
Bill G
Member Posts: 8
Gentlemen,
I looked at a job yesterday that perplexed me. It was a converted gravity system. There are two mains: Left side of house 2 1/2" main and return, Right side of the house 2" main and return. The system is a direct return layout. Both supplys are fed with 1 1/4" lines from the same size manifold. The returns are brought together into an 1 1/4" return. Each side has 2 radiators upstairs and three rads downstairs. Only the first upstairs rad on the left side heats. Even with all of the hand valves on the first floor rads closed, he can't get heat to any rad except that first rad. He has a 0011 pump on the return. Each rad has 6 - 3/4" elbows. He is going to put a series 100, as Dan suggests, in place of the 0011. Any other ideas? Thanks in advance!
How much radiation
is on that system? Even a B&G 100 can be too big for some systems- like mine.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0
- 86.7K THE MAIN WALL
- 54 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 934 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
