TACO ZV Wiring
Bill L.
Member Posts: 4
Can someone help me with my wiring...my TACO zone valves won't open. I need to leave them in the open position instead of the auto position..here's what I have....(system is a gas fired boiler for a baseboard heating system..just heat..no hot water)
ON THE TRANSFORMER IN THE BOILER
**from the "G" terminal
-1 wire into junction box where relay is connected.
-1 wire from terminal#2 on the zone valve
-1 wire to the left terminal on the limit (temp) control
**from the "R" terminal
-1 wire from thermostat(s) (i.e.- white wire)
**from the "C" terminal
-1 wire into the junction box with the relay
-1 wire to the "TR" terminal on the gas valve
FROM THE "TH" TERMINAL ON THE GAS VALVE
-1 wire from "TH" to the limit control's right term.
ON THE ZONE VALVE(S)......
Terminal #1
-wire from thermostat (i.e. red wire)
Terminal #2
-wire from terminal "G" on transformer
Terminal #3
-??????? where does the wire that connects to this terminal originate????? in order to operate valve?????
My questions.....
? could the relay be bad?
?? What is the middle terminal on the gas valve (un-used at this point) used for..labeled "TH-TR"
---other pert. info.----
Transformer plate reads
120V 60Hz 25V 40VA Class 2 transformer
ANY HELP WILL BE GREATLY APPRECIATED......i'm hoping to add pics to help you help me...
Terminal #1
Terminal #2
Terminal #3
My questions.....
Let's see if this works
Mark H
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0 -
quick drawing
this is a quick drawing, i used differnt colors for drawing purpose only. you can only use up to 3 of those zone valves on each transformer. If the drawing isnt clear, check the instructions that came with the zone valves. or even easier, buy yourself a Taco zone control panel, and use that, wire it according to the instructions.
Chuck Shaw
Zone Valve Wiring
Is this a Weil-McLain CGa boiler?
If it is then conventional Taco zone valve wiring will not work. Send me an e-mail and I will get you the correct diagram.0 -
Really Tim?
I must have more than a dozen CGa boilers in the field that are wired that way and working fine.
Chuck
That is the wiring dia. that comes with the TACOs. It works with everything.0 -
Chuck, the CGa
I am talking about has a vent damper, with a Honeywell control center (transformer and relay) combination.0 -
Did you guys get my
e-mail today? Is this the type of system that you are dealing with. Did the diagram help?0 -
yup!
Check your e-mail.
Thanks!
Mark H
Tim was a BIG help
I just wanted to thank Tim in the open forum here. And i also want to let all of the non-believers out there that the wiring diagram that Tim sent me worked indeed.
Again, thanks a lot Tim....0 -
Glad to help Bill...
call anytime.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
