Pipe capacity
[Deleted User]
Does anyone have a chart or link to a site that lists how much water is in 1' of various types of copper and black pipe?
Try this...
http://pages.prodigy.net/rich_demartile/files/pipe-vol.xls
I don't think you need to worry about the difference between different types of pipe. 1" ID is 1" ID regardless of type of pipe, plus or minus a few thousands of an inch...
ME0 -
your the one that would know it
> -vol.xls
> ME
mike,
has anyone put all those formulas and charts on palm pilot?0 -
don't know about the Palm thingy.....
but Siggy has a great program called Hydronics Design Studio, and it will give you the secrects to MANY hydronic questions!!!
Check it out.....
http://www.hydronicpros.com/
Geeeeeeeeeeeeeeees, I wish a had abuck for every time I have recommended this program since I got it!!! :-)
Floyd0 -
now if can
get it to run on my windows CE device...0 -
I only need to know
how much water is in a given diameter pipe, (3/4, 1, 1 1/4 ect) mainly copper. I saw the information about 2 months ago and, of course, forgot where (should have printed it and put it in the pile of information you don't need right now, but when you do, you can't find).0 -
There is a neat little book called Pocket Ref by Thomas J. Glover
it has just about anything you want to know as far as formulas and such. For how much water is in a pipe just do volume of a cylinder Pi times radius squared times total length. One gallon of H2O=231 cubic inches=8.33 pounds@65 degrees F.0 -
according to ziggi..
in an artical in plumbing & mechanical mag,
when you are calculating expansion size,
many times you can use half at 65 and half at
max hot temp
this is especially true for large radiant like
a snow melt system where the return is pretty cold0 -
4.26 gal per 100ft 1\"cu pipe
www.copper.org is a Copper tubing website has all the specs.on gallons per liner feet of pipe. Go to applications and click on tube,pipe and fittings.0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 929 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
