an awful noise
jaybee
Member Posts: 128
Im a newbi to this feild and just recently a trade school graduate at a tech school that was more geared toward a/c and refrigeration spectrum.At my house my wife was in the kitchen washing dishes and when she turned on the water there was a horrible noise and when she turned down the water the noise went away. What could this be and how can I correct this problem??????
Thanks jaybee
Thanks jaybee
Loose faucet washer, sometimes.
Noel is right
If it just started happening , a loose washer is probably the culprit . You can also get banging noises from a globe valve installed in the wrong direction of flow .0
- 86.7K THE MAIN WALL
- 54 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 934 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
