steam radiator uneven heating
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,600
http://www.heatinghelp.com/steam_radiatorsnotheat.cfm
Retired and loving it.
  • harry_3
    harry_3 Member Posts: 3
    steam uneven in radiator
    I have a one pipe steam radiator with a "C" vent. Radiator is 48" high x 7 sections x 3 column. Radiator is pitched and vent hisses air. However only the first 3 section get hot (even when I let the system run for an hour). I rodded the bottom of the radiator - found no obstruction. Any ideas? why 4 sections are not getting hot?
  • scrook_2
    scrook_2 Member Posts: 610
    Bad main vent...
    on the main feeding the radiator perhaps, forcing the radiator vent to double as a main vent? Very long riser to the radiator which must also be vented?
