RHEEM HOT AIR HEAT EXCHANGER
MARK_21
Member Posts: 19
Hello all-I was wondering if anyone can tell me if the heat exchanger comes out from the front of the unit? I have to change the heat exchanger and chamber-comes as a kit now from rheem.. I have the ROBC 084 QAAA Thanks so much--also are there any web sites that show how the exchanger is removed... Thanks and Happy Newyear to all!!
MARK
MARK
this link
should help out a lot!
http://www.heatexchangerexperts.com/
although might not be exactly what you were looking for0 -
Oil furnace
Mark , the heat exchanger comes out the front of the furnace. Not a bad change out. I believe the fan/limit control is seperated on the replacement unit and the furnace uses a fan off delay timer control. This is all part of the kit.
Bring the vacuum cleaner to remove the old gasket material from the front panel and flue collection box.
The instructions from Rheem have been very good. With lots of pictures.
Good luck,
WD0 -
THANKS SO MUCH FOR THE EXCHANGER INFO....0 -
Rheem drum
I agree, not a bad job. Easier than most.0
- 86.6K THE MAIN WALL
- 54 Biomass
- 100 Chimneys & Flues
- 5.6K Gas Heating
- 101 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 934 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
- 48 Job Opportunities
