What is a normal pressure rise?
Ken C.
Member Posts: 267
If a hot water boiler has a pressure of 12 pounds when the water temperature is cool, how high should the pressure gage read when the water temp is around 190-200?
Trick question
Each system will give you a different answer unless you plan. I'm inclined to run in the 20psi range with most of my radiant, slightly higher with cast rads @ design temps. System volume, temperature rise and expansion tank acceptance volume all contribute. Enjoy....Dan
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0 -
Mine does that
Thanks for asking the question Ken, and thanks for the answer Dan. I have a small single story house with a single loop baseboard system and it does exactly as Dan stated. My system seldom ever gets over 170 degrees (W-M WGO-3. I had planned to ask the same question. Mark R.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
