Burnham Heeeeelp!!!!
Richard D._2
Richard D._2 Member Posts: 156
Hello and thankyou..I know there is a Burnham tech here but(sorry forgot his name!! I have a ? on a MOD-V-905...Ser.#29000416 ...Large hole in back section..Big enough for my fist with room.. 1 more crack ,all around top section #3, crack the width of boiler,section #2 and 1?????. Do I need to wait till mon. to get the paper trail started...??Just trying to speed the papere work process! Can I drill and tap the back section and patch with a steel plate for a temp/patch?? Will that void warrenty???You can call me at home if you want or I can call you.I can send phone # e mail ...Thanks Richard
  • missafossa
    missafossa Member Posts: 3
    burnham help
    Sir you definitly need to get ahold of your installing contractor or the rep
  • tim smith_2
    tim smith_2 Member Posts: 184
    cracks!!!!!!!!!!!!!!!!!!
    Sounds like a dry fire, I am really urging you to have a professional look at this, major problems if a hole in the section is that big.
  • bob young
    bob young Member Posts: 2,177
    you need a new boiler. if it dry-fired and you try to repair it you may be wasting your cash. fix it once and get it over with. only patch if you are destitute.
  • Richard D._2
    Yea
    I hear you ...I was trying to do a patch till block gets here..It will be ordered on Mon....My Co.will be installing it..Right now the customer has electric heat but just wanted to have more heat if needed,,,Never had to hole in a steamboiler like that before...All good advice as usual from the wall... THANKS for your replies and concern!!! Richard
  • Richard
    If this is configured as a steam boiler, I would strongly suspect that one of the water level controls is not working the way it was intended to and that this boiler was dry-fired. Before completing this changeout, I would take a real close look at the low water cutoff or pump controller. This boiler should also be installed with an auxilliary Manual Reset LWCO per CSD-1 Code to guard against things like this. I'd like to satisfy my own curiousity by knowing what level control devices were on this boiler. Let me know that information if you don't mind. Thanks.
    Glenn Stanton
    Burnham Hydronics
  • Richard D._2
    I will
    Check it out on Mon...Will talk soon Thanks
